advice on clutch setup
Old Apr 26, 2015 | 02:55 PM
klu408's Avatar
Default advice on clutch setup
I just bought a nv4500 conversion for my 01. It had a southbend clutch setup that came with it and the upgraded input shaft... the only kicker is the clutch Is a dual disk 36005 competition setup... will this be fairly streetable? I have nowhere near that kind of hp but I have hardly any money in the clutch and hate to not use it.. opinions please
Old Apr 26, 2015 | 03:31 PM
dieselrick's Avatar
You will hate that clutch as it will not slip on normal takeoff and will chatter like a SOB if you try. If you have the SBC flywheel with it, call south bend and ask if pressure plate is same as their single disk OFE kit & if so, just order correct OFE disc only. Very smooth and actually streetable. Is trans used or new? If used, check input shaft for play up & down for looseness and if it hits t/o bearing sleeve, he probably rattled the bearings out of it.
Old Apr 26, 2015 | 03:33 PM
klu408's Avatar
It's used but looks like new. Inside and out. What would this clutch be worth used?
Old Apr 26, 2015 | 03:49 PM
dieselrick's Avatar
Check their website for price on that kit and general rule on used GOOD parts is 60% of new. Keep the flywheel but check that input shaft for play as it will haunt you later. It shouldn't move more than 1/8". If that kit comes with flywheel, subtract 200$ from new price and sell for 60% of that. Did you get the SBC hydraulics with trans?
Old Apr 26, 2015 | 03:53 PM
klu408's Avatar
Yeah the clutch is 1940 new. It has stock hydros on it.
Old Apr 26, 2015 | 04:47 PM
dieselrick's Avatar
They will never last with that pressure plate. I'm fairly certain the pressure plate with the DD kit is different as well. The upgraded input shaft I believe is a 1-3/8" shaft while stock 5 spd is 1-1/4". If you can sell that clutch kit for a grand, I can sell you the single disc OFE kit with flywheel and HD hydros for 1150.
Old Apr 26, 2015 | 04:48 PM
klu408's Avatar
Well help me sell it..
Old Apr 26, 2015 | 07:52 PM
dieselrick's Avatar
Funny guy! Just ask anyone, they know the most, I go by experience.
twinturbo12v
Price Quote - Request A Price
Oct 6, 2015 07:30 PM
coach101
Sep 22, 2015 09:36 PM
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
Wyocumins
Oct 19, 2014 09:34 PM
