12 valve makes ticking noise from pump and dies
Old Apr 24, 2015 | 06:06 AM
btg2820's Avatar
Default 12 valve makes ticking noise from pump and dies
Hello I have a 1994 12 valve and after it warms up I hear a ticking noise from either p pump or injectors running out of fuel.. then sometime i will either lose throttle comtrol or it starts to tick and then slowly die. I turn the key off then give it a couple turns and it fires right up.. put new lift pump and overflow valve.. any help would be awesome
Usuallu happens when it is warm not when its cold
Old Apr 27, 2015 | 12:09 AM
97cummins's Avatar
what kind of fuel presure from the ppump are you seeing?
mr. dune-a-holic
May 4, 2015 01:39 PM
moneypitk5
Feb 12, 2015 11:01 AM
