Sudden stop - no crank, no start
Old Apr 24, 2015 | 12:47 AM
K31TH's Avatar
Default Sudden stop - no crank, no start
Had my 04 Crew DRW Just over 2 months. Bought with 184k miles. Had no previous issues until it suddenly stopped running merging onto freeway. I immediately threw into neutral and attempted to restart after having read that can sometimes work. Of course it didn't. Pulled over and tried again. No starter engagement, no click ( like batteries dead). Dash lights (in fact all lights) work properly. Let sit hoping was temp related. 30 mins later, still no starter engagement. Towed home. Next day, no starter. But now noticing no fuel pump turn on. All lighting still ok. Visually Checked all fuses - all good. Swapped around relays - no change. Replaced batteries (Interstate megatron 2 with overnight charge) - no change. Used working ECM from sons truck - no change. Attempted to use AE (after successfully connecting prior to failure) - would not talk to ECM.
Car fax states head bolts replaced at 48k and at 66k by Ford dealers
Could talk to ECM with AE prior to failure. Cannot now
Replaced IPR within last 200 miles due to leak. Also would surge at idle
No other running issues before failure. Previous AE measurements all look good
Known good ECM no change
Acting like gear selector is in gear (AT) but changing position does not improve. Also not getting fuel pump to come on either
Starter turns over normally when voltage applied to connector under hood passenger side
Looking for any help you guys can give.
Super stumped as to no fuel pump with ignition on
Old Apr 25, 2015 | 12:25 AM
saranay's Avatar
Sound like electrical issue.
Can you get your starter to run? Without using ignition key.
Most common I have seen is the fan wires got shorted.
Check your fan connection wire. Look inside the fan shroud. Disconnect the connection try to start it.
Keep disconnect each component connection out and try to start it one at the time.
ish1521
Aug 26, 2015 08:42 PM
tmcc14
Apr 21, 2015 03:59 PM
ebg2g
Mar 29, 2015 06:15 PM
musikagod
11
Nov 30, 2014 07:22 AM
dango
Oct 19, 2014 07:57 PM
