low exhaust temp question
Old Apr 20, 2015 | 02:31 AM
Noodle's Avatar
Default low exhaust temp question
I am new to diesel engines and just built a 12 valve with a 58mm turbo and 75hp injectors. Stock fuel plate (for now) all the way forward. I have a bad intercooler hose clamp and most of my boost is leaking out. New clamp in the mail but my egt doesn't get above 500 degrees. I feel like even with my issues that is extremely low. Also, my fuel pressure is about 7 psi at idle. From what I've read i feel like that is also extremely low. Any help is greatly appreciated.
Old Apr 20, 2015 | 01:53 PM
JBearSVT's Avatar
That EGT and fuel pressure are both extremely low. How does the truck run?
Old Apr 20, 2015 | 03:04 PM
Noodle's Avatar
Lower rpms is a little rough and it seems like it's giving outa little early in the upper rpms but pulls hard in the mid range.
Old Apr 20, 2015 | 05:05 PM
JBearSVT's Avatar
Sounds like a genuine fuel issue, but all bets are off until you get the boost leaks squared away. Where are you measuring fuel pressure at?
Old Apr 20, 2015 | 06:24 PM
Noodle's Avatar
Fuel inlet at injection pump. I'm new to diesels and turbos so I'm kinda lost but I'm thinking with no boost that cylinder pressure is lower than it should be and is causing the low egts but I really have no clue. I read several places that the stock lift pump would support my setup but have no clue about that either.
Old Apr 21, 2015 | 05:51 PM
JBearSVT's Avatar
It would if it was working properly. It may be about to die, or you could have an air leak in the line somewhere.
Old Apr 21, 2015 | 06:43 PM
Noodle's Avatar
I will check all the fuel lines. Should have boost issue fixed on Thursday or Friday. I will update my progress then.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
irondog1954
Jul 21, 2015 09:57 AM
Flatbed2001
Jul 8, 2015 04:17 AM
robbyS
Apr 16, 2015 02:22 PM
