Vacuum pump is squealing I think.
Old Apr 16, 2015 | 02:03 PM
InheritedDiesel's Avatar
Default Vacuum pump is squealing I think.
When I crank it up there is a very irritating squeal coming from the vacuum pump "area." I recently changed the tensioner pulley so that is not it for sure. It goes on for a bit then quiets down. Sometimes it never quiets down. I am worried it is about to go and grenade my belt.
Should I replace the pump, or get the PCM/mechanical wastegate upgrade?
Old Apr 16, 2015 | 06:34 PM
RanchhandTCR's Avatar
First Id take your belt of before you start it one day and spin some components around to see what seems to be hard to turn or have play in it, do that so you have a better idea of the issue rather than wasteing money.
Old Apr 17, 2015 | 07:20 PM
Mayhem's Avatar
X 2 what ranchhand says I have seen bad belt tensioners tear up a few alternators as well as a couple of P.S. pumps take that belt off and check out whats going on before spending money.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
DeLuzGN
Mar 17, 2015 08:08 AM
moneypitk5
Feb 12, 2015 11:01 AM
