High Readings on Oil Pressure
Old Apr 8, 2015 | 07:43 PM
DodgeCummins99's Avatar
Default High Readings on Oil Pressure
I have a 1999 Dodge Cummins. When I started it up today the oil pressure was reading a little over 40 and when I started driving it was on the max line for PSI, but never goes over. After the engine warms up completely the pressure will return to normal. It usually runs a little under 40 at idle and a little over 40 while I'm driving. Has anyone else had a problem like this or know what could be going wrong.
Old Apr 10, 2015 | 05:01 AM
gh0stman's Avatar
My pressure varies all the way from 22 psi at idle to 40ish at drive speeds to 60+ under acceleration. I don't think you have an issue.
Old Apr 10, 2015 | 05:56 PM
I know that it is gonna fluctuate when I accelerate, but when the engine is cold the pressure reading is over 40 and when I accelerate its at the max line. As the engine warms up it returns to its normal readings of 20 psi at idle and 40 psi when I'm accelerating. It just started doing this a about a 2 weeks ago.
Durtyd09
Nov 11, 2015 01:43 PM
BKID
Jul 25, 2015 07:59 PM
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
