6.5 mysterious oil leak
Old Apr 5, 2015 | 04:36 PM
Gomerpile79's Avatar
Default 6.5 mysterious oil leak
Hello all, I am new to this site.
Well, I recently purchased a 1998 3/4 ton GMC Sierra with the 6.5 Detroit. I noticed a few little oil spots on my driveway so I went under there to check things out, and on the driver's side, oil was on the oil pan, and all in the area. The area around the oil filter was also covered in oil. I then wiped everything off to make it dry, and a little tight area around the oil filter began to very snowly leak. Has anyone else ever run into this problem? and If so, what could the problem be and how much money would you say it would cost to fix? My immediate suspicion is the valve cover although input would be nice.
Old Apr 5, 2015 | 05:13 PM
Mayhem's Avatar
Oil cooler lines more than likely and you will want to fix this as soon as possible or they will fail and you will be looking for an engine.
Old Apr 5, 2015 | 07:42 PM
Ok I did some research about oil cooler lines and some have said that the factory ones aren't that great and aren't known to last very long, do you know if there are aftermarket ones available that are more reliable than the factory ones?
Old Apr 6, 2015 | 11:00 AM
SS force's Avatar
There are multiple aftermarket sellers for new lines, they are steel braided and come with the adapters to the block and a new oil cooler,
This is where I got mine.
GM 6.5TD/6.6L Diesel: Espar Heater Parts, EZ Oil Drain Valves & More Industrial Products by the Lubrication Specialist
Old Apr 9, 2015 | 09:53 AM
InheritedDiesel's Avatar
Put new oil filter adapter seals as well while you got it off.
You have to get the big O ring from the dealer.
The kits sold by all the parts chains is the same and doesn't include the right big O ring.
Old Apr 9, 2015 | 03:45 PM
Mayhem's Avatar
I just went through this, Just go to the dealer and for around $40 you can get all the right stuff and have 4 spare sets minus the copper O ring.
cummins Pride
Sep 28, 2015 12:11 PM
markv8993
Jun 21, 2015 12:24 AM
big Mikey mike
Jun 18, 2015 08:44 AM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
