changing belt tensioner and belt
Old Mar 26, 2015 | 01:35 PM
Ironmanqb's Avatar
Default changing belt tensioner and belt
Going to replace my belt tensioner and belt. Any tips on how to thread the new belt back on? I'm trying to figure out how it gets around the fan.
thanks
5.9 12 valve 1997 Ram 2500
Old Mar 27, 2015 | 03:44 PM
JBearSVT's Avatar
There should be a routing diagram on the radiator support?
Old Mar 27, 2015 | 09:55 PM
Ironmanqb's Avatar
I have the diagram, that I understand. I'm trying to see how the belt goes on the pullys with the fan shaft in the way. Does the belt get threaded between the radiator and fan, and get pulled over the shaft? Sorry if I'm not making sense.
Old Mar 27, 2015 | 10:06 PM
kubiak's Avatar
yes i get the belt over the fan blades one by one till they are all over and on the fan shaft first then route it around the pulleys then have a big ratchet on the spring pulley then
pull it over the ac compressor pulley from the bottom while i have spring pulley pulled back.
Old Mar 28, 2015 | 10:51 AM
JBearSVT's Avatar
Yes, between the fan and radiator first.
Old Apr 4, 2015 | 07:35 PM
Kruze. 96's Avatar
The way I just did it was put the belt on one blade of the fan and turn the fan and as it goes around push the belt behind each fan blade. I dont know if that makes sense then if you get the biggest socket wrench you have it fits into the tensioner pully so that you can pull it over to get the belt on it. I think the ratchet is a half inch drive. I hope that all makes sense
Old Apr 4, 2015 | 10:27 PM
kubiak's Avatar
once you do it, the next time shouldnt take more than a few minutes to change the belt. i got used to taking mine off to clean the oil off the belt when i had a oil leak from the front cover.the belt would start squeeking when it got too much oil on it.
JasonG.
Ford Powerstroke 08-10 6.4L
Feb 26, 2015 08:51 PM
denpenn
Feb 11, 2015 11:29 PM
mnbf48
Jan 19, 2015 09:20 PM
Floydfan38
Sep 28, 2014 06:21 PM
