Power steering fluid leaking from the Master Cylinder?
Old Mar 18, 2015 | 10:31 AM
bryan0702's Avatar
Default Power steering fluid leaking from the Master Cylinder?
Craziest thing with this truck. I replaced the power steering pump, and the leak stopped. 3 weeks later one of the hoses split down the middle, I replaced the hose and the leak has stopped. 2 months later there is a puddle of PS fluid under the drivers side tire, and I am thinking WHAT NOW!! It looks like it is leaking at the master cylinder, but that can't be right?
Any idea's
Old Mar 18, 2015 | 12:05 PM
jrsavoie's Avatar
https://www.google.com/search?q=Brak...+brake+booster
Old Mar 18, 2015 | 05:03 PM
Mayhem's Avatar
Welcome to HydroBoost, the ps pump does all the work because turbo diesel's make no vacuum, here is an example hope this helps and you should try and fix it as quick as you can due to the mess they can make.
if it is not a bad hose it more than likely is one of the o rings
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
GCTownes
Oct 21, 2014 10:17 PM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
