6.5 w/ auto trans. code 22
Old Mar 16, 2015 | 12:13 PM
apehangerjoe's Avatar
Default 6.5 w/ auto trans. code 22
code 22 tps sensor low . reads 35 , stays there thru full thottlr range, have no rpm readings on trans input sensor ,output sensor , replace tps. changed tcm with junk yard one . ohm wiring harness between sensors & tcm plug , tach on dash working . truck won't shift out of second ,out of idea's , any one have this problem.
Old Mar 16, 2015 | 04:16 PM
HeavyChevy95's Avatar
fwiw
Attached Thumbnails 6.5  w/ auto trans. code 22-dtc-22a.jpg   6.5  w/ auto trans. code 22-dtc-22b.jpg
Old Mar 26, 2015 | 03:01 AM
tornado842's Avatar
I have had a blown fuse cause the truck to only have 2nd and reverse. Have you verified the fuses? Have you checked for voltage at the sensors?
DieselDan_5.9
Jul 30, 2015 07:05 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
kydieseltech
May 28, 2015 05:00 AM
countryboy040993
22
Nov 12, 2014 11:25 AM
UC Kid
Oct 23, 2014 05:29 PM
