1997 chevy 6.5 liter k3500 loss power steering when i letoff throttle
Old Mar 13, 2015 | 10:33 PM
krg3590's Avatar
Default 1997 chevy 6.5 liter k3500 loss power steering when i letoff throttle
pretty sure its the power asset,put a new pump.i had to put the old power asset accuater and sensor in it.need to find a power steering pump that already has the sensor and accuater together.any ideas help!? anything i could have did wrong.any suggestions.?
Old Mar 14, 2015 | 08:39 AM
Mayhem's Avatar
Are you saying power steering pressure sensor in the back of the PS pump? If so get a PS hose for a 1995 and this will delete that deal all together I have had to do this on a couple trucks in the past.
Old Mar 15, 2015 | 12:33 AM
krg3590's Avatar
Sorry if this sounds stupid. Which line do I get. Do I get the line that runs from the gear box to the pump I cant even think of the other line but they are both high pressure lines? Have you heard anything about the bypass kit GM made. It takes the sensor completely off. My first diesel truck so I am new at this. Any other suggestions about what to do or not to do. thanks for your help.
Old Mar 15, 2015 | 08:57 AM
Mayhem's Avatar
I tried that $100 bypass kit from gm on a truck was told that it was the only way to fix the high pressure line comming out of the pump, on the next truck I had with the same problem I compared to 1995 and found that the hose from the 1995 worked for about $70 less and one less connection to leak.
Captain Fear
Dec 3, 2014 05:35 AM
GCTownes
Oct 21, 2014 10:17 PM
Cougdiesel
Oct 19, 2014 10:09 PM
