Cooling system
Old Mar 13, 2015 | 10:25 PM
yz450f269's Avatar
Default Cooling system
Hey guys....newbie has a question..... changed out the radiator in my 04 f350 6.0....AT...4x4.....145,000...... my question is....is there an air bleed for the system....and is a coolant filter worth the money?.....and about how much trans fluid is lost in the cooler?...
Thanks
Old Mar 14, 2015 | 10:50 PM
78fordman's Avatar
Probably a couple of quarts lost total, make sure to use mercon sp or lv, not mercon 5. As for the coolant filter yes run one. It will prolong the life of your oil cooler. Make sure to not use standard green coolant, use ford gold or the preferred coolant is red cat ec1 rated coolant.
Old Mar 15, 2015 | 12:38 AM
yz450f269's Avatar
Crap......do i have to flush system or can i just drain............in order to switch.......where do i find red coolant
Old Mar 15, 2015 | 02:27 PM
78fordman's Avatar
O Reilly auto parts usually has it, it's behind the counter though. Just drain the green and fill with tap water several times until it comes out clear, no chemicals. Then drain and fill with distilled water then drain and fill with coolant. The block retains a lot of water with just the radiator drained. You will need to put 3.5 gallons to straight antifreeze in to get a 50 50 mix. The entire system is 28 quarts iirc.
Old Mar 15, 2015 | 05:31 PM
yz450f269's Avatar
Thanks for the info.....is there an air bleed i need to worry about
Old Mar 15, 2015 | 05:36 PM
78fordman's Avatar
No air bleed, just fill up and start and let idle a couple of minutes and check again. While your working on the cooling system, go and buy a new cap. Most trucks running around have bad caps.
Old Mar 15, 2015 | 08:56 PM
excutioner's Avatar
a coolant filter does nothing for the oil cooler.the water passes through the cooler then through the filter which is to late.i am in the process of making a system that filters as soon as it leaves the block and before it gets to any coolers."NEVER USE FORD GOLD" there are a couple of you tube videos on what that crap will do to your system.the elc-1 cat coolant is the best hands down and is the only thing that i use in my trucks and customers trucks.you can also use the g05 it's pretty good.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jul 14, 2015 05:40 PM
