vacuum issues
Old Mar 13, 2015 | 01:24 AM
cutthroatxxx's Avatar
Default vacuum issues
OK so here is all of what I have going on & nothing figured out so I'll start fresh.When I bought the truck I noticed this green vacuum hose was unhooked also so was the electrical connection to the exhaust brake. I do not believe there is an exhaust brake on this truck. I see nothing in the exhaust which is an aftermarket 6 inch, well I had air coming out of the front vents. put in a new transfer case and now No air out of anywhere but the defrost& the four wheel drive does not work.
I found this vacuum hose disconnected and if I run it to the Green Line... Which please if you know what this green line is for let me know anyways... I get four wheel drive but in a two wheel drive position meaning the linkage is in 2 high
& it only goes into 4 wheel drive in one of the positions though the 4 wheel drive light comes on in all positions but one. But still air only out of the defrost. I bought a posi lok to lock the 4 wheel drive in manually but I know vacuum leaks can cause excessive blow by so I want to fix the vacuum leak. I found the line with the disc is supposed to connect to the T fitting that is going to the exhaust brake. so I don't know if I should remove the exhaust brake and put it back to how it was originally because there still has to be something this was hooked too.And this braided line coming off the back of the terminal goes to a brown vacuum line it's actually kind of the squares line with black heat shrink around it what is this for? Sorry for the poor grammar I usually use speech to text but today its really bad I cannot use my right arm long story. any thoughts help ideas would be greatly appreciated.I do body work for a living and I was shocked yesterday that a fellow called me and wants me to come see his 2007 I believe 4 door long bed 4 wheel drive with the 6.7 he wants to give it to me for some work. But that doesn't mean I want to toss this truck aside.Ive Pub plans for a 2nd gen Cummins sense I learnt about them after I bought my 95 gas burner& I I have no plans to abandon this truck so please if you can help I would appreciate it plus I might change his mind or want to make some kind of crazy deal Thank you
http://s303.photobucket.com/user/CUTTHROATXXX/media/Mobile%20Uploads/20150311_185733.jpg.htmlhttp://s303.photobucket.com/user/CUTTHROATXXX/media/Mobile%20Uploads/20150311_195449.jpg.html http://s303.photobucket.com/user/CUTTHROATXXX/media/Mobile%20Uploads/20150311_185720.jpg.htmlhttp://s303.photobucket.com/user/CUTTHROATXXX/media/Mobile%20Uploads/20150313_004307.jpg.htmlhttp://s303.photobucket.com/user/CUTTHROATXXX/media/Mobile%20Uploads/20150313_004228.jpg.htmlhttp://s303.photobucket.com/user/CUTTHROATXXX/media/Mobile%20Uploads/20150313_004213.jpg.html[URL=http://s303.photobucket.com/user/CUTTHROATXXX/media/Mobile%20Uploads/20150313_004207.jpg.html][IMG]http://i303.photobucket.com/albums/nn159/CUTTHROATXXX/Mobile%20Uploads/20150313_004207.jpg[/I
Old Mar 13, 2015 | 08:41 AM
scottxmorris's Avatar
I had the same issue i could move the 4x4 shifter and would in engage in the transfer case but the front end would not engage turned out to be a dry rotted vacuum line coming from the power steering pump i connected it back up and air vents work now with the 4x4...check the vacuum solenoid on the front end as well as the line coming off the power steering pump it runs along the top of the firewall and goes to the passenger side into the cab near the a/c condenser. Hope this helps!
dwmeehan
Jan 29, 2025 12:13 PM
DC_DC41
Jul 16, 2015 09:56 PM
DeLuzGN
Mar 17, 2015 08:08 AM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
