Help! Truck shutters while shifting into overdrive!
Old Mar 7, 2015 | 09:00 AM
FF131's Avatar
Default Help! Truck shutters while shifting into overdrive!
Right after my truck shifts into overdrive it will shutter pretty good until I give it extra fuel then it Will go away. The shutter is much worse when I'm going up a hill right after I switch it into overdrive but if I hit the accelerator quick it'll go away. It only does this in overdrive, not at a certain rpm either. The speed is usually somewhere between 45-60 mph. Is this my tq converter saying adios?
Old Mar 9, 2015 | 04:45 AM
gh0stman's Avatar
I have the same issue but only when the truck is tuned out of stock form. And only when its in the torque band (1200-1600 RPM) and is boosted over 10-12 PSI. Do you have any mods on your truck? If not you could have an issue with the OD unit.
Old Mar 9, 2015 | 06:23 PM
FF131's Avatar
Yeah I have a comp box. It's strange
Old Mar 10, 2015 | 04:04 AM
gh0stman's Avatar
Now don't quote me but I think it may have something to do with the valve body too. I have no data to support. But if my spidey senses are correct, trying to cram that much torque through something that can barely handle stock, it has a hard time possibly with getting enough pressure to go like it needs to. This is all speculation no data or research to back it up.
But I noticed a few months ago, if I get the RPM over 1600, that I could boost as much as I wanted with no jump from the trans.
Old Mar 13, 2015 | 04:18 AM
gh0stman's Avatar
Disregard all previous posts. I found the solution to the problem. Change your Diff fluid. I changed mine yesterday with some Royal Purple and it no longer happens. When the old stuff came out it was dark as night.
Old Mar 26, 2015 | 06:35 AM
bubba411's Avatar
So changing differential fluid fixed it from jumping in and out of overdrive I dont see how
Old Mar 26, 2015 | 06:42 AM
gh0stman's Avatar
What I was talking about was under load it would start bucking in OD. What you are talking about is alternator related. The alternator ac noise causes the TC to lock and unlock. Fixes for that include a new alternator.
Old Mar 26, 2015 | 06:49 AM
bubba411's Avatar
Alternator and then what from there
Old Mar 26, 2015 | 06:51 AM
gh0stman's Avatar
There are many threads across the internet about the ac noise from the alternator. Rather than butcher it, look it up on google and you will find a lot of information. The best I have seen so far is Moparman's guide.
Old Mar 26, 2015 | 07:06 AM
bubba411's Avatar
Thanks
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
SixSpeed
Jan 11, 2015 01:41 AM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
Oct 14, 2014 08:40 AM
