Miss at idle when warm
Old Mar 5, 2015 | 09:54 PM
02Stain's Avatar
Default Miss at idle when warm
I have an 02 24 valve that has a consistent misfire at idle when in park and warmed up. Fuel pressure bounces between 19-21 psi when it's missing. All I know about the engine is that its fire ringed, 200hp injectors, 66mm turbo, ats exhaust manifold, with an AirDog II lift pump...im sure im forgetting some things. It idles fine on cold start up with only a little hesitation at low speeds under light throttle but after a few miles the throttle response is back. No check engine light, no dead pedal. Any ideas guys? Im totally new to the world of diesels! Thanks for any help/advice.
Old Mar 18, 2015 | 10:40 AM
ERK's Avatar
ERK
I replaced the cam and crank sensor on mine and it went away
moneypitk5
Feb 12, 2015 11:01 AM
Lbarsnick
Feb 10, 2015 08:40 PM
cdetterer
15
Dec 8, 2014 08:46 PM
hunt4beer
Nov 15, 2014 09:06 AM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
