built 12valve ??
Old Mar 4, 2015 | 09:44 PM
Kbnecessary's Avatar
Default built 12valve ??
Ok so I finally found a extra motor for my truck that in fixing to start building I was thinking of doing 12mm mainstud girdle but how much power would u be pushing to need a 14mm studs and how much can factory rods take was prolly gonna run a small sets of twins so would marine hg and studs be fine or would that be to much and need fire rings
Old Mar 5, 2015 | 08:52 PM
coors_man_2005's Avatar
You should be fine w/o fire rings at most I would o ring for a street truck. I'm going to be running Allan bolts with marine gasket. I already have my parts just need some time to install everything. I hear of guys sled pulling around 70-80#'s of boost and holding?? We will see I guess
Old Mar 6, 2015 | 07:18 AM
I put a set of them in my brother s truck u better have a good socket cause I broke a couple
Old Mar 6, 2015 | 08:43 AM
94 12valve's Avatar
For a street truck a o ringed head with studs will hold whatever you throw at it. As for your bottom end question do not waste your money on a girdle it is not needed or 14 mm main studs also not needed for a street truck.
For the bottom end put new bearings in along with 12mm main studs, upgraded rod bolts, balance the crank, rods, and pistons this will give you a very stout bottom end.
Old Mar 6, 2015 | 09:15 AM
I bought some 1/2 drive Impact Allan's. So we will see haha
Old Mar 6, 2015 | 07:45 PM
Would it be worth the money to shot peen and polish the rods for strength
Old Mar 6, 2015 | 07:57 PM
I'm doing it to my build to my 6.7. With my 12v rods. I done some searching And cant remember who it was. But it was very reasonable. Correct me if I'm wrong but shot peen and polish do the same thing to an extent. Correct that's just what I gathered from what I read
Old Mar 6, 2015 | 08:31 PM
Yes they prolly do i just want sure if shot peen would take out casting ridge
Old Mar 6, 2015 | 08:35 PM
Do u have any expierence with mahl pistons was looking into buying engine kit from pure diesel power with coated mahl pistons
Old Mar 7, 2015 | 06:18 AM
94 12valve's Avatar
IMO no its not for what your doing just a balance and upgraded rod bolts will be all you need.
Yes I have ran them in my puller for a few years now with good results.
carid
Group Buy
Apr 16, 2015 08:38 AM
rajdiesel
Mar 14, 2015 07:11 AM
Walker.B
Chevy/GMC Duramax 01-04 LB7
12
Feb 21, 2015 03:08 PM
Nov 28, 2014 09:50 PM
bajahigh
Oct 8, 2014 01:29 PM
