Edge EZ what all do i need
Old Mar 3, 2015 | 05:48 AM
bodock's Avatar
Default Edge EZ what all do i need
Good morning brand new here and a rookie to all the diesel upgrades Old guy looking for alittle better mileage and towing seen all the stuff on chips and tuners kinda curious if ya need to do anything else other than just plug it in???? just want to add alittle help
Thanks to all from Tn
Bodock
Old Mar 3, 2015 | 01:04 PM
DODGEARMYGUY's Avatar
Bodock
Depends on how you plan to use the tuner. First and foremost, gauges are always a recommended prior to installing any tuners. Reason being, you're altering the stock settings of your ECM and motor, and you never know how well received that is going to be. For that reason, its best you have a way to monitor the basics - Fuel, EGT's, and boost. To provide you with an example - my truck started and ran perfectly fine with the stock lift pump. I install a FASS 150 and all of a sudden I'm experiencing sparatic fuel pressure issues. Had I not installed a pressure gauge, I would be driving the truck around unaware of the sparatic pressures my VP is now experiencing, as the truck will start (for the most part) and drive around just fine.
In terms of additional parts required for a tuner/programmer/ whatever you want to call them, you may need an upgraded lift pump to supply a higher rate of fuel to the injection pump. FASS and Airdog seem to be the two highest rated, and most commonly recommended, pumps. However I would say reasearch to see what fits best with your application. I.e. certain tuners on certain levels WILL require fuel flow that the stock lift pump simply can't supply, whereas others, set on lower levels, can operate on a stock lift pump. Regardless though, an aftermarket lift pump is always suggested over the stock lift pump with, or whitout, a tuner or other modifications to the truck.
Here is the typical suggested modification order for our trucks by most people -
# 1 priority = gauges
# 2 Lift pump
# 3 Transmission build if you have an Auto
# 4 Tuner/Programmer
# 5 Turbo and Injectors
As you can see, the first three priorities are just getting under-par stock parts up-to-par, then you start adding the performance modifications in.
Hope this helps.
Old Mar 4, 2015 | 11:29 AM
gh0stman's Avatar
What DODGEARMYGUY said is true. You have to build reliability into junk oem part areas then move to the fun stuff. As for lift pumps I would stay away from Airdog, lately they have been having a lot of issues from what I have seen. Fass is the better way to go IMO.
Old Mar 5, 2015 | 08:13 AM
bodock's Avatar
Thanks guys very helpful look forward to learning a lot from ya'll
Old Mar 5, 2015 | 12:30 PM
tbirdz24v's Avatar
As fas as installing the Edge it comes with everything you will need. It plugs into the map sensor and the data link under the hood. Then you just run the selector switch to the dash and mount it. That's about it.
justinsbeck
Jan 18, 2016 12:15 AM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
somarillw
Dec 8, 2014 09:07 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
