lift pump leaks
Old Feb 25, 2015 | 01:55 PM
ktfroy's Avatar
Default lift pump leaks
My truck died this morning and with the cold weather I thought it might have gelled. After cleaning out the pre-filter all the fuel looked good so I tried to prime with the lift pump and fuel is coming out around the rubber primer cover.
truck wont start so I am wondering if this leak at the primer pump would translate into a pressure loss in the lift side - does that sound right?
thanks - Roy
Old Mar 5, 2015 | 07:25 PM
Kbnecessary's Avatar
If its leaking out primer button then yes our lift pump is toast try a new one
Old Mar 11, 2015 | 11:13 AM
ktfroy's Avatar
thanks for the response, I appreciate it.
after replacing this thing 2 times now I want to ask for a replacement that will last longer than a couple of years.
Any suggestions?
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
