Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
At What Point Is Adding Weight Gonna Help?
Old May 13, 2008 | 07:19 AM
RSWORDS's Avatar
Default At What Point Is Adding Weight Gonna Help?
My 89 Cummins Puller weighs in at 5750 with me in it... Seeing as how I am in a 8000 class that leaves ALOT of weight I can play with.
I ran this run with 1600 lbs in my tool box because we can't hang weights but can add it.
(I'm in the white 1st Gen)
Then I made this pull the next weekend with no weight added...
I pulled farther and faster w/o the weight... Was this a fluke? I'm thinking that my little VE with just pump mods does not have the power to get the extra weight down the track...
I have since added some POD's and now and in a delema... Do I add the weight this weekend or not?
Old May 13, 2008 | 07:25 AM
Whit's Avatar
Site Mascot
I aint an expert but I would say dont add the extra weight
I think ya need gov springs to up the RPM and get yer wheel speed up
Old May 13, 2008 | 08:02 AM
RSWORDS's Avatar
Got a 3200 spring... the damn 2:1 transfer case and 3.07 gears are KILLING me.
Old May 13, 2008 | 08:10 AM
RTL Garage's Avatar
I Personally Think Its The Paint Job
Old May 13, 2008 | 08:25 AM
RSWORDS's Avatar
BWWAAAHAHAHAHAHAHAHA... SHUUT UUUPP....
The Paint Job is part of the sleeper look... Whats sucks for me though is the other part of the sleeper look (being fast) has not come together yet.
Old May 13, 2008 | 08:59 AM
babydoll214's Avatar
Bobert's Girl
I think that the crappy tin roof paint is causing extra drag and slowing the whole thing down...
Old May 13, 2008 | 10:47 AM
2500HeavyDuty's Avatar
if it was red it would be faster
Old May 13, 2008 | 10:52 AM
DangerousDuramax's Avatar
What Whit said, you need to get your wheel speed up but with those 3.07 gears your screwed unless you're making about 1000hp.
Old May 13, 2008 | 03:10 PM
LOGANSTANFORTH's Avatar
shorter tires or swap the gears for more RPM, and yes there are 4.10 and 4.56's available now for Dana 61/71's from Randy's Ring and Pinion now......are you running in first gear in the transmission and not shifting........
how did you pull in comparison to the other trucks, if you always pull with the same 10-15 trucks (like we do in ohio) and your always placing around the same place or same distance behind or in front of the other trucks at every pull you got a good truck, now if everything is "perfect" and this happens, you got a consistent truck, now once you have consistency, you start slowly tweaking and turning and moving and playing with stuff, ONLY CHANGE ONE THING AT A TIME, I CANNOT STRESS THAT POINT ENOUGH, IF IT WORKS KEEP IT, IF IT GETS WORSE PUT IT BACK, and keep a small notebook and write down stuff like track conditions, tire pressures, how many trucks, what place you pulled, what place you finished, all that stuff, so you can log your consistency, cause if the first weekend you was running a "lead sled" and the second weekend you was on a "drag race sled" you will have 2 completely different distances, even the same sled on different tracks will have different distances.......with a lead sled you need the low end grunt and gain speed until the pan slows you to a stop, with a drag race sled you need wheel speed then cause when the pan hits your going to eat steering wheel......it can take several pulls to get the truck tuned just right to what it likes......try putting some of the weight on the floorboard next time.......
***NO TWO PULLS WILL EVER BE THE SAME, NO MATTER HOW CLOSE THE VARIABLES ARE***
Old May 13, 2008 | 11:45 PM
that only works if theres a pull every weekend....
only once a year for me
