Stuck in 2nd gear wont shift!!
Old Feb 24, 2015 | 10:28 AM
aoutlaw95's Avatar
Default Stuck in 2nd gear wont shift!!
This is my girlfriends truck its a 01 dodge ram 2500 cummins and thought we figured it was govenor pressure solenoid so changed it took it for a spin and it shifted first to second fime now its back in second and won't shift at all the ony codes ots reading is glow plugs my only other guess is maybe torque converter but before i fork put 1200 bucks i need some other opinions please help me out guys!
Old Feb 26, 2015 | 08:46 AM
98cummins's Avatar
Can you get readings from the trans as far as pressures? scanner should be able to show you what the sensors are seeing.
Old Mar 3, 2015 | 09:02 PM
aoutlaw95's Avatar
Hooked my code reader up to it and got governor pressure solenoid and torque converter overdrive solenoid! So i started replacing solenoids firt goemor solenoid cause its cheapest then overdrive solenoid as i was trying to het the valve body down for the overdrive something popped of the top so ended up pulling entire valve body off ended up finding that the boost valve retainer was broken(probably not the main problem but lucky find) and that her accumulator spring was also broken! So probably
Didnt have to go through changing all the solenoids but i would definitely urge anyone when replacing solenoids or anything internal on the transmission to pull valve body while youre in there if you havent had any work done recently and check it out thoroughly!
6.2Lturbo
Chevy/GMC Duramax 01-04 LB7
Aug 15, 2015 01:25 PM
Daniel Leipart
Jun 28, 2015 02:42 PM
Hotrodd_67
Jun 22, 2015 09:50 PM
EverettsGMC
Mar 29, 2015 05:42 PM
rabidrabbit
Mar 6, 2015 03:47 AM
