throttle position sensor P0122
Old Feb 23, 2015 | 11:31 AM
Jmohr52's Avatar
Default throttle position sensor P0122
Check engine light came on about a month ago read a p0122 throttle position a circuit low and so i reset it and it worked until today. Dodge wants 650$ for a new one, but I found the aftermarket one at geno's garage for 200$. Has anybody used one from them and will it work on my 5.9 24 valve?
Old Feb 24, 2015 | 09:36 PM
gyayo2012's Avatar
just went threw the same thing, with my truck i ended up going to autozone and getting one for 200$ they had it in stock, a few days later a buddy of mine had the same problem (dead pedal) and ordered one on ebay for 20 bux if it was now i would have just gotten a cheap ebay apps..
Old Mar 2, 2015 | 10:03 AM
Charliethorn's Avatar
Default Cheap TPS reliability?
Do cheap TPSs work? Where do I look for this info?
Old Mar 4, 2015 | 01:18 AM
BlueRacer's Avatar
Timbo Apps http://www.dodgecumminsapps.com/index.html[/URL] You might check this one out. A thorough check on the alternator is a good idea before getting in a big hurry to replace the apps. Frequently dirty voltage is the cause of problems, and no advance/autozone can't tell if your making dirty power. The alternator output can be fine and still be noisy with a.c. voltage if the rectifier is crapped up. It will jangle the ecm inputs/outputs and make it forget apps set points as well as cause trans shifting problems, etc.
1997silverado
Sep 7, 2023 06:20 PM
burndiesel
10
Feb 7, 2023 01:15 AM
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
1stgenswap
Nov 3, 2014 09:45 PM
