1998 12 valve boost limits
Old Feb 20, 2015 | 11:14 PM
Str8sixpack's Avatar
Default 1998 12 valve boost limits
Would 45psi of boost be safe with on a cummins 12v with stock studs? Herd if you simply re
Torque them you good 45psi? Is that a Myth or what? Ha idk.. You guys tell me.
Old Feb 21, 2015 | 03:31 AM
Just-Another-Dieselguy's Avatar
The myth is boost blowing head gaskets.
Old Feb 21, 2015 | 07:11 AM
JBearSVT's Avatar
Indeed. If 45psi blows a head gasket (and it can) it's only because it was already compromised. 1998 12V's in particular tend to have a little bit worse machine work on the deck than others, so the heads don't always fit perfectly flat. Regardless, boosting stock parts that high is more likely to burn up your stock turbo than blow a head gasket.
Old Feb 21, 2015 | 08:38 AM
wpg6.5's Avatar
you won't likely blow it at 45 psi with the bd special. most gaskets blow because of drive pressure and cylinder pressure, your running a large turbine side and not very much timing so you should be good for a while. are studs suggested, yes. very much so. your into performance diesels and skimping on important parts is never a good idea, but it will last you a good while if you don't drive like a dick. also the 300 marines probably aren't that efficient and have a lot of unburnt fuel so your cal pressure is also likely a bit lower because of that
Old Feb 28, 2015 | 11:32 PM
captain_stabbin's Avatar
i've been blowing 80lbs an nos threw mine for 3 yrs an no issues, no rings!!
Alaskabound
Aug 27, 2015 06:42 AM
Alaskabound
Aug 20, 2015 07:00 PM
torino73
Apr 14, 2015 11:15 PM
hoeky22
For Sale
Mar 15, 2015 08:35 PM
LTreis702
Feb 14, 2015 12:52 PM
