Crank, no start
Old Feb 17, 2015 | 08:28 PM
armybassanglers_james's Avatar
Default Crank, no start
2006 F250 Powerstoke, AEM cold air intake is the only mod I have on it.
It died on me about a week ago while driving, had it towed to house. Pulled IPR to check the screen and it was clear. I went and bought a Scan Gauge II/X Gauge and got the following results while cranking. Only code I am getting is P0671 (#1 cylinder glow plug circuit)
IPR - 84.7 %
SYC - 1
ICP - 0
FMP - 49 volts
I can't remember what each is suppose to be , but I am assuming that its the ICP that's bad. Any input would be greatly appreciated.
Old Feb 18, 2015 | 07:04 PM
Adrenaline junkie's Avatar
Bad sensor or high pressure oil leak. Check hpop pressures. If old style, the pumps were questionable. Newer ones develop oil leak in feed to rails
Old Feb 19, 2015 | 04:51 PM
Thanks for the reply, the feed to rails you are referring to is that the STC on the HPOP?
Old Feb 23, 2015 | 07:15 PM
Yes that's the newer problem. The tubes leak
Old Feb 25, 2015 | 09:38 PM
Kiss8108's Avatar
I was wondering if that fixed the problem? Ours has died on twice now while driving and have no clue what's wrong with it.
Old Mar 5, 2015 | 03:51 PM
excutioner's Avatar
i have seen the windings in the ipr break down under heat this will shut the truck down.when the truck shuts down does it start right back up.
Old Mar 5, 2015 | 07:03 PM
Kiss8108's Avatar
No the truck will not start back up. It has been down for a couple of weeks now with no clue as to what could be causing it. We are have to take it in.
Old Mar 5, 2015 | 07:23 PM
excutioner's Avatar
when it died it started back correct but now it wont.
Old Mar 5, 2015 | 07:27 PM
Kiss8108's Avatar
No it never started back up.
Old Mar 5, 2015 | 07:41 PM
excutioner's Avatar
i sent pm
