95 12 valve died, now no start
Old Feb 16, 2015 | 01:11 PM
RayRay4991's Avatar
Default 95 12 valve died, now no start
Went to start truck this morning, about 25*F, cycled grid a few times, started up ran rough for a sec then cleared up. Was running fine for bout 3 minutes, then it started stuttering and died, now it wont start. Got it to run for a couple seconds with foot on throttle but then it just dies. primed lift pump a whole bunch and still nothing new. Lift pump bad? IP bad? And fuel filter was changed within the last 2 months.
Old Feb 16, 2015 | 07:59 PM
Benjamin's Avatar
Bombardier
depending on your location it could be gelled fuel maybe?
check and make sure the fuel shutoff solenoid is in the up position when cranking, if it isn't that is your problem. should be down to shut the truck off, up to make truck run. if it won't stay up look for the light blue wire going to the battery and there is a fusible link that burns out when the solenoid goes bad. you can wire tie it up for the time being to get you from point A to point B....
next would be to check the overflow valve to make sure it isn't stuck open allowing the fuel to just pump straight through the pump and go back to the tank.....
Old Feb 18, 2015 | 08:26 AM
RayRay4991's Avatar
Fuel Shut off is working like it should. When I prime the pump I can hear a whining noise at the OFV, not sure if that makes a difference.
Old Feb 18, 2015 | 02:59 PM
Bigg Redd's Avatar
Sounds very much like your fuel has gelled up. It will never start or run if thats the case.
Old Feb 23, 2015 | 07:45 AM
six speed's Avatar
i had one do this last year. the fuel had gelled. pull the fuel filter out and if i remember right the fuel line below the lift pump and blow the fuel line back into the tank. get a bottle of diesel 911 and put in the tank. replace with a new filter and try to prime again.It worked for me. then keep some additive in the tank to keep it from gelling.I always keep additive in the fuel but I had ran out last year and it went from 50 to 10 degrees in just a few hours. Lesson learned.
moose2j
Jun 21, 2015 12:36 AM
PeteBug
Jun 11, 2015 12:16 PM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
Tyler_302
Oct 22, 2014 07:08 PM
6_in_a_row
Sep 30, 2014 11:31 PM
