Sputtering at higher rpm?
Old Feb 12, 2015 | 08:59 PM
Cornfed95's Avatar
Default Sputtering at higher rpm?
Truck sputters really bad at about 2000 rpm ? Truck is completely stock exept for straight pipe and grinded fuel plate to a 0. Was thinking maybe injectors. Any feed back is much appreciated!
Old Feb 20, 2015 | 11:21 PM
Str8sixpack's Avatar
-fuel filter
-bad fuel overflow valve
-timing my have slipped
-sloppy injector
Old Feb 26, 2015 | 08:49 PM
coors_man_2005's Avatar
Mine was caused from the over flow valve. It sputtered like hell upper rpm. Installed a tork tek ofv.. Runs great now. Good luck with yours only about $40 fix
Old Feb 28, 2015 | 11:29 PM
captain_stabbin's Avatar
does this only happen under no load?
Old Mar 3, 2015 | 01:32 PM
4x4manonbroke's Avatar
Mine was a bad OFV as well .. yes no load
Mine also was having high EGT's also ... major improvement since the tork tek install
Taylor03
Jun 6, 2015 11:09 AM
InheritedDiesel
Apr 12, 2015 04:35 AM
gingerbreadman
Feb 1, 2015 05:42 PM
dutchsupreme
Dec 18, 2014 01:44 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
