94 gmc 2500 6.5 turbo cracked heads
Old Feb 12, 2015 | 11:57 AM
greatlakes diesel's Avatar
Default 94 gmc 2500 6.5 turbo cracked heads
I'm asking for some input i have a 94 gmc 2500 6.5 turbo was leaking coolant so tore the heads off to find that driver side head blew the head gasket. I cleaned the heads to take them to get resurfaced found cracks between the vavles should i clean them up more and run them.btw the casting numbers on the head is 10137567
Thanks rusty
Old Feb 12, 2015 | 08:46 PM
1997silverado's Avatar
You might be able to make it work but personally I'd just swap them for a new (I'm sure someone will chime in with a good upgrade or aftermarket I haven't really looked into a head upgrade yet) or GOOD used set it sounds like more headaches ahead, if you already have stress cracks the metal is already weakened. I'd rather put it back with parts I could trust. Just my two cents
Old Feb 12, 2015 | 08:48 PM
Not to mention it could end in much more pricey damage depending on how they fail spending a dollar to save a nickel as it were
Old Feb 13, 2015 | 08:28 AM
Yea i thought money spent on gaskets bolts just to put it back together and a chance that they would be junk
Thanks Rusty
Old Feb 13, 2015 | 09:55 PM
detroitdiesel idi's Avatar
Don't scrap them brass liner tubing can be installed and coolant won't leak through they'll be better than new search on youtube 6.5 cracked head fix
Nathanator
Aug 30, 2015 03:51 PM
timmyd
Jun 8, 2015 11:35 PM
detroitdiesel idi
Dec 27, 2014 10:03 PM
Snoobly
Dec 11, 2014 11:59 AM
gremlin75
Oct 6, 2014 06:10 AM
