popping out of exhaust miss
Old Feb 10, 2015 | 07:05 PM
Power Ram Man's Avatar
Default popping out of exhaust miss
OK I have a 92w250 that I installed a 95 p pump engine out of a f700 medium duty truck a 190 HP pump completely rebuilt engine .20 mahe pistons with marine bowls, new colt cam stage 3 with 24 valve lifters, head studs .10 head gasket , 4k govoner spring in pump , 0 fue plate 200 HP injectors timing set at 18 degrees pump was rebuilt 220 fass installed head was redone with new guides,seals and seats the problem I'm having is the truck has a popping sound miss out of the exhaust you can see the truck shake it does it bad when cold when its hot its noticable but not nearly bad already replaced overflow valve and injectors no help don't have fuel pressure gauge hooked up yet could this be a fuel issue still? I pinched off the return line with no help I have thought about valve issues but I just had the head reworked ? Any advise
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
