Some White Smoke?...
Old Feb 10, 2015 | 03:08 PM
sgreen3's Avatar
Default Some White Smoke?...
Hey fellas I have a 97 Cummins 5speed 4x4 and I do have the fuel plate removed. My question is when Im taking off in either 1st or 2nd I will get some cutting out and white smoke. But then when you hit 3rd gear its fine power comes on strong and no cutting out or white smoke. Is this from having the fuel plate removed? It does it real bad when the engine is cold but still does it some after its reached operating temp. I pretty sure the white smoke is raw fuel so maybe a lack of air in the lower gears is the cause. your thoughts?.... Thanks fellas....
Old Feb 20, 2015 | 11:42 PM
Str8sixpack's Avatar
Sounds liked slipped timming.
Old Feb 21, 2015 | 03:32 AM
Just-Another-Dieselguy's Avatar
I agree. Check timing
Old Feb 21, 2015 | 01:56 PM
kryz9903's Avatar
Check timing and make sure you have proper fuel pressure
Old Feb 24, 2015 | 03:34 PM
sgreen3's Avatar
Ok thanks fellas Ill Have to do that. I was wanting to have the timing bumped anyway might be a good time to do that I guess.
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
zoomer10h
Feb 6, 2015 01:38 AM
ASarsano
Oct 15, 2014 05:33 AM
