6.2 engine trouble
Old Feb 10, 2015 | 11:34 AM
85Burb's Avatar
Default 6.2 engine trouble
Had a new engine put in my '85 suburban about two weeks ago with about 40k miles on it. Compression test was perfect and it was ex-military so I was confident in it. Anyways, a few days ago it started making a noise like a bunch of screws in a blender, grinding and rattling. I checked the oil and it was fine. The engine will crank up after a few tries but will start making that noise as soon as it kicks on. This may be one of things that you have to hear/see for yourself to get an idea but just thought I'd check to see if anyone had any ideas before pull the engine or tow it to a mechanic. I'm really hoping it's not the engine but that's what I suspect. Any help would be much appreciated!
Old Feb 10, 2015 | 02:27 PM
racer55's Avatar
Have a look at the balancer on the crankshaft.
If it has become un-bonded it may be rattling against the drive pulley?
Old Feb 10, 2015 | 03:04 PM
Bigg Redd's Avatar
Also, If its an automatic, check your torque converter bolts and make sure they havent come loose and backed out a bit. Happened to me when I had an 80 chevy c3500 dually. Just a thought........
Old Feb 10, 2015 | 07:22 PM
85Burb's Avatar
It doesn't sound like something is loose. Not saying it couldn't be a loose bolt or something but it's pretty loud and whatever it is, it was enough to cut off the engine when the problem initially happened.
Old Feb 10, 2015 | 07:47 PM
Bigg Redd's Avatar
Can you possibly post a vid of the issue, so we can hear it? That may help a bit.
Old Feb 10, 2015 | 07:53 PM
Bigg Redd's Avatar
What part of the engine do hear this noise coming from?
Old Feb 11, 2015 | 02:07 PM
85Burb's Avatar
It's hard to tell where it's coming from while in the drivers seat and I'm afraid to leave it on long enough to get out and listen. If I had to guess it sounds like somewhere between the engine and transmission. I'll put up a video as soon as a figure out how to post one on here
Old Feb 11, 2015 | 09:09 PM
Bigg Redd's Avatar
a second pair of ears will help. Have a buddy or other listen while you start it or you listen while another starts the engine.
Old Feb 25, 2015 | 12:28 AM
detroitdiesel idi's Avatar
Sounds like maybe flywheel ring gear seperation
Old Feb 25, 2015 | 12:32 AM
Chevy 6.2 Diesel Trouble! Help!: http://youtu.be/jwQ7KCPalgQ
