Edge cts problems
Old Feb 7, 2015 | 11:27 PM
David4684's Avatar
Default Edge cts problems
I recently bought an edge juice with attitude cts and I have everything hooked up correctly and the little yellow light for the safety feature won't go off and the truck has lost most of it power anyone know what's going on?
Old Feb 9, 2015 | 05:25 AM
gh0stman's Avatar
What are you backdown settings on? If they are set to low you will end up defueling because under normal operation the box says you are past normal. If you know what I mean.
Old Feb 9, 2015 | 10:20 PM
David4684's Avatar
Not to sure have to look what should it be at?
Old Feb 13, 2015 | 09:00 PM
Baradium's Avatar
Also check your cold temp backdown, you could have that too high as well causing it to always wait for the truck to be warmed up.
Old Aug 8, 2015 | 02:50 PM
burt_boi's Avatar
I have a edge juice also and when I get any where between 40 and 50 mph and I'm just crusing the fuel will cut in and out like its cutting out when I give it the gas it's fine then start cruising again and it does it again anybody know how to fix that
Old Aug 10, 2015 | 03:59 AM
gh0stman's Avatar
That was a rough read. What is your fuel pressure at the moment? I doubt it has anything to do with the edge. When was the last time you hooked it up to the computer to update it?
Dr67
Apr 30, 2015 12:36 PM
Bowling_77
Feb 22, 2015 10:58 AM
Kfohne21
Feb 16, 2015 03:46 PM
Opresik
Feb 11, 2015 03:59 AM
Opresik
Feb 8, 2015 12:34 PM
