So here is ,my build...is MPG where it should be?
Old Feb 6, 2015 | 11:41 AM
relic530's Avatar
Default So here is ,my build...is MPG where it should be?
2002 5.9
Stock Auto trans /w 3.55 gears
Quadzilla adrenaline
S&B Intake
blue chip vp44
gauge pillar with fuel pressure, always reads higher than 15psi
295/65/18 nitto trial grapplers
4 inch magnaflow turbo back with muffler delete.
stock turbo.
150k miles
Basically I am averaging 13 in stop and go and 16.5 freeway with no load.
Now the ECU has not been calibrated to the tires so I figured out a 7.6% less revolutions per mile from stock tires. Are these fuel numbers seem reasonable?
I was thinking about getting my valves checked. and checking for leaks in the intercooler piping. What Do you all think?
Old Feb 21, 2015 | 11:31 AM
amztroyer's Avatar
seems low to me, i get about that and im running 4.88 in my f550
Old Feb 21, 2015 | 01:52 PM
kryz9903's Avatar
Yeah that's pretty low mileage. I'm averaging between 14.5-16.3 mpg right now. That's with letting it idle for about 10 minutes since its been in the negatives the past couple weeks. Mines a 96' 3500 stick with 4.10 rear end. I'd definitely get it checked into
Old Feb 21, 2015 | 06:53 PM
BikerBri327's Avatar
My stock 99 has been really low, like 11.5 lately. I think it's because it soo cold and my engine isn't heating up fully. That's on the highway mainly 70+ mph. Usually, it was much higher like at least 16 or more. I believe my injectors are stock with 206k miles. Does anyone know what injectors to use for straight out highway running that will seriously increase mileage mainly?? Thanks..
Old Feb 21, 2015 | 07:08 PM
relic530's Avatar
Oh i forgot i have Bosch rv275 injectors
Old Feb 21, 2015 | 07:33 PM
amztroyer's Avatar
RV 275's are one of the better mpg injectors, but that is a whole can of worms, there are many different opinions on which injectors get the best mileage.
I am leaning towards getting F1 mach 1.6 injectors
Old Feb 21, 2015 | 07:44 PM
relic530's Avatar
I don't know much about injectors. I think the bigger tires causes worse mpg, even though i didn't think they did
bbilt
5.9L Rotary Performance
May 29, 2015 07:05 PM
Jan 14, 2015 03:40 PM
jtwthaxj
Diesel Engine Conversions
Jan 14, 2015 06:52 AM
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
Nov 29, 2014 12:40 AM
Omingnome
Oct 20, 2014 12:25 PM
