06 3500 dead pedals under harsh acceleration
Old Feb 5, 2015 | 07:43 AM
jpl92's Avatar
Default 06 3500 dead pedals under harsh acceleration
I was towing a small bumper pull horse trailer and i went to pass up a car and i floored it and so the truck started spoiling up and all of a sudden i hear a loud pop out the exhaust and a lil cloud of white smoke and my truck just coast loss of all power and goes no were so i hit the pedal agin and it did the same thing with out the pop in the exhaust the truck drives perfectly fine under normal acceleration but if i hit the pedal all the way down it just shifts up and then just coasts what could it be? Help this is my fisrt cummins just bought the truck a month ago
Old Feb 5, 2015 | 08:57 AM
dangerous1965's Avatar
Have any gauges? Sounds like rail pressure spike. Then a defuel occurs. PRV pressure relief valve possible cause. Are you running a tuner or is it stock?
Old Feb 5, 2015 | 10:03 AM
jpl92's Avatar
No its stock the only thing ive done to is straight pipe it
Old Feb 5, 2015 | 06:50 PM
South Texas Goat's Avatar
Check your air to air connections, sounds like one is cut or loose
Old Feb 7, 2015 | 02:14 PM
spark'd's Avatar
go under the hood pull the main engine harness plug apart and give it a clean and put it back together
