won't start
Old Feb 4, 2015 | 03:28 PM
alan1966's Avatar
Default won't start
I have a 03 6.0 that won't start, the ac compressor is froze so I took the radiator, fan etc. Off with the belt off should it start
Old Feb 4, 2015 | 03:58 PM
Adrenaline junkie's Avatar
If it's just ac compressor, yes it will start. I wouldn't run it long since they flow a LOT of water in cooling system.
Old Feb 4, 2015 | 04:40 PM
alan1966's Avatar
Default won't start
Ok,
Old Feb 5, 2015 | 12:50 PM
alan1966's Avatar
Default won't start
I have a 03 6.0 that won't start, the ac compressor is froze up so I took the belt off and still won't start, it ran fine before the ac compressor froze up. I've replaced the hpop, icp, ipr what might be the problem, any help would be great
Old Feb 6, 2015 | 12:48 AM
detroitdiesel idi's Avatar
what is your ficm voltage at?
Old Feb 7, 2015 | 04:12 PM
alan1966's Avatar
Default won't start
I think I screwed up, didn't have the volt meter set right when I touched the ficm it sparked, did I fry it
Old Feb 7, 2015 | 09:55 PM
good possibility did you proceed to check voltage after you arched it?
Old Feb 8, 2015 | 01:41 AM
alan1966's Avatar
Default won't start
Yeah it was 00.2
Old Feb 8, 2015 | 04:03 PM
I would bet it was fried already. If you can get known good ficm I would try that. Usually power board goes out but logic side is pretty reliable. Gotta test and see what's going on. Lots of info here and videos on how to test ficm. Make sure you do not cross contacts in ficm!
Old Feb 8, 2015 | 04:10 PM
alan1966's Avatar
Default won't start
Going to see if I can get one from junkyard send the other one to be fixed, hope that it fixes it, thanks
