Supplemental grounding of starter
Old Feb 4, 2015 | 11:59 AM
james2562's Avatar
Default Supplemental grounding of starter
The starter went Tango Uniform. In the process of removing it I was able to break the lug where the positive wire attaches to the starter. So I ordered a new Remy starter part number 96100 ($140.00) and a new 2/0 cable for the starter. I was looking to beef up the ground for the starter but only saw a very small ground lead for the starter solenoid.
Is their anything I can do to beef up the ground for the starter?
Old Feb 4, 2015 | 06:56 PM
Mayhem's Avatar
Clean the engine block real good before mounting the starter and if the engine grounds are good to go you are golden.
Old Feb 5, 2015 | 05:45 PM
racer55's Avatar
Most important thing to have on the starter is the nose strap to the block!
Old Feb 5, 2015 | 06:10 PM
james2562's Avatar
What nose strap? I do not see any on the schematic you attached and I did not disconnect any when I took the starter off.
Old Feb 5, 2015 | 06:14 PM
racer55's Avatar
#9 on the 6.2,6.5 starter picture
Could also be more properly called a brace or bracket.
Old Feb 5, 2015 | 09:05 PM
james2562's Avatar
Got it. Thanks.
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
TMP025
Chevy/GMC Duramax 01-04 LB7
Feb 16, 2015 12:27 AM
nevadagramm
Oct 17, 2014 07:59 PM
thunderball52
Oct 6, 2014 08:08 PM
