Throttle position sensor
Old Jan 29, 2015 | 02:57 PM
1997silverado's Avatar
Default Throttle position sensor
Does anyone know of a way to check a throttle position sensor on a 97 silverado 6.5 turbo diesel other than installing a new one I have parts trucks with known working tps one a 94 one a 99 (99 tps is brand new changed it about a week before someone ran a red light and t-boned me) that I could switch over but I'm not sure of the compatibility, both parts trucks are gas burners and I'm not sure if they use the same system or if anyone knows if they are compatible with my trucks electronics. I'm not trying to cut corners just hate to spend money on a new part when I'm not certain it's the issue and I already have a new one and a lightly used one already laying around
Old Jan 29, 2015 | 04:48 PM
Alright guess I should have looked the 99 plugs differently and the 94 has a cable nevermind
Old Jan 31, 2015 | 08:32 PM
UC Kid's Avatar
I had the throttle position sensor (cps) code come up, but when I went under to look at it, I found that the metal piece that bolted the cps in had come loose so that when I removed the nut the metal piece fell off, which must have allowed it to move slightly. I have a 1998 gmc 6.5 TD. I ended up puttiing in a new one and code never came back and truck started up well.
Old Jan 31, 2015 | 08:40 PM
thanks for the reply finally broke down and paid for a new one fixed that particular problem
Old Feb 5, 2015 | 05:52 PM
racer55's Avatar
Bit late I guess but here is the test info:
Injection Pump my AZZ - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Old Sep 7, 2023 | 06:20 PM
TEllis's Avatar
Default Help please
can anyone help me locate the throttle position sensor please I’ve tried everything to find it
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
robbyS
Apr 16, 2015 02:22 PM
Moly Squid
Mar 28, 2015 04:26 PM
Jmohr52
Mar 4, 2015 01:18 AM
