Steering sound
Old Jan 27, 2015 | 03:13 PM
efeaganes's Avatar
Default Steering sound
When I'm driving down the road and steer left on a turn there's a thumping noise coming from the front end on the drivers side. Any ideas as to what it could be?
Old Jan 27, 2015 | 07:38 PM
HeavyAssault's Avatar
Check the trac bar mount on the drivers side. Then check the trac bar mount bolt. Verify all the hardware is torqued correctly.
Old Jan 28, 2015 | 09:51 PM
efeaganes's Avatar
I looked and the boot in between the pitman arm and drag link is pretty worn out. Could this be the problem? It doesn't always make the noise just sometimes.
Old Feb 3, 2015 | 03:42 PM
Zejokee's Avatar
U-joints in axle shaft drive side? That is assuming your truck is 4x4
Old Feb 6, 2015 | 04:26 PM
No. The trac bar mounts to the frame on the driver's side and the axle on the passenger side. Solid bar...no adjustments can be made.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
