Tuning 5x16 injectors with s363. 360hp?
Old Jan 26, 2015 | 09:07 PM
CGME's Avatar
Default Tuning 5x16 injectors with s363. 360hp?
I have a 95 12v auto with 5x16 injectors, 4k GSK, 16.5* timing, #0 fuel plate, 024 DV's with an s363 turbo that maxes out my 60psi gauge.
I put it on the dyno and it did 360/800 but I have friends with smaller set-ups putting out higher numbers, and people on here getting huge numbers with similar setups.
I've tried everything that I can do, I've set the fuel plate/smokescrew/starwheel/housing at every possible combination but nothing seems to make much of a difference. Does anyone know any other options I could do?
Old Jan 26, 2015 | 10:03 PM
wpg6.5's Avatar
That's very strange. What 363 turbo do you have? Box? Wastegated, that could be your first problem. I'm assuming you have the fuel plate close to full forward and the afc set up so it doesn't over fuel? what's your fuel pressure? Is the ip stock? You could be running out of fuel and at 60 psi I think a 363 is way out of map. You'll make more power at 40-45 I think with a 63. You need a wastegate
Old Jan 26, 2015 | 10:05 PM
wpg6.5's Avatar
I made 360/828 on 5x12 and a he351. So you should have a lot on me and I just did 16s and it feels much stronger. Something's going on, what ofv do you have?
Old Mar 5, 2015 | 09:30 AM
easttn12valve's Avatar
Maybe bump up the timing to 18°. Unsure just a suggestion.
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
