6.7 pushing out coolant out overflow tank
Old Jan 25, 2015 | 03:06 PM
egghead's Avatar
Default 6.7 pushing out coolant out overflow tank
We change the head bolts to ARP 625 and after 4000 miles she started it again LOST need some help
Old Jan 25, 2015 | 11:15 PM
97cummins's Avatar
possible bad radiator cap
Bocked passage way in head.
blown head gasket
are you have issues starting,or getting white smoke?
You can also check to see if you have any loose hose clamps for the radaitor surge tank.
Hope this helps.
Old Jan 26, 2015 | 09:01 AM
egghead's Avatar
Thanks but new rad cap its looking like head gasket ****
Old Feb 6, 2015 | 06:37 AM
1ton butcher's Avatar
Just curious, what are you seeing for boost when your noticing coolant from tank? Also, did you swap studs 1 by 1 or have you had a gasket blow already?
Old Feb 6, 2015 | 08:03 AM
egghead's Avatar
Well we found that their was a hair line crack in the EGR Valve going into the coolant.... yes we have change the head bolts one at a time all is GREAT NOW
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
RatsMC
May 4, 2015 05:25 PM
coors_man_2005
Dec 15, 2014 10:23 AM
