taking a lot of cranking before diesel fires up
Old Jan 23, 2015 | 11:10 PM
UC Kid's Avatar
Default taking a lot of cranking before diesel fires up
There is a lot of grey smoke before it finally starts up. Has been -35 to -40. Since end of December till now it sat and does not want to start up. Blows grey smoke and smoke rings, but does not start. Would this be a glow plug issue. Have never changed them and truck has over 200,000 miles on it. What should I check and if needed what are the best glow plugs to get?
Old Jan 24, 2015 | 10:03 PM
racer55's Avatar
Bosch Duratherm glows are what you want.
Might also try using the block heater anytime it gets below -10.
Old Jan 24, 2015 | 10:46 PM
UC Kid's Avatar
Thanks, I use both a block heater and I have another magnetic one that I put on the bottom of the oil pan at -25 Celsius. It has been starting, but taking way too long before igniting. I hadn't used it since a week before Xmas and it has been into the -45 Celsius range lately. Again, thanks a lot for the advice on part type as I know you prefer AC Delco parts most often.
UC Kid
Old Jan 25, 2015 | 03:12 PM
petew's Avatar
zero weight synthetic is a big help in our climate for starting.
Old Jan 25, 2015 | 07:06 PM
whiteknightironrange's Avatar
Default cold start
You may also want to try blending your fuel half tank #2 and half tank #1. Or if you are really having a hard time getting it going running straight #1 in extreme cold weather like you described wouldn't be a bad idea.
Old Jan 25, 2015 | 09:33 PM
UC Kid's Avatar
Thanks a lot you guys. I did buy 0 synthetic and a filter, but should have put it in a month ago. Have glow plugs coming and will change the oil at same time now that I have it in the shop and the weather is above 0 Celsius, odd for January, which is usually -35 or bouts. You mention blending #2 Zander #1 half and half. What do you mean by that, not following that.
Old Jan 26, 2015 | 10:46 AM
#1 diesel fuel has a lower flash point than #2 diesel fuel. Meaning that the cylinder temperature can be lower and the diesel fuel will still ignite. The way I mix my fuel is that I run my truck down to half of a tank and fill up with the other fuel than last time. If I filled up with #2 last time that would mean filling up with #1 this time.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
