Electrical help
Old Jan 20, 2015 | 06:26 PM
Josh4430's Avatar
Default Electrical help
I have a 1997 12v all my indicator light come on and flash along with my voltage gauge showing not charging and all this happens only when truck is moving forward with engine under load or just rolling forward does not do it in reverse or setting at an idol not moving. I had alternator check and its good.
Old Jan 21, 2015 | 05:32 PM
kubiak's Avatar
check the grounds and wire connections. could be a loose wire hanging and grounding when moving foward. could be a wire being pinched when torque of the motor moves too. my buddies truck ran perfect till he gave it gas then it would misfire like crazy, we found out it was a spark plug wire being pinched by the motor because of a bad motor mount. i know yours is a diesel but check all your electrical wires and grounds.
moparman70
Jul 30, 2015 12:38 AM
culp7
14
Jul 20, 2015 10:13 PM
coryfast
Jul 6, 2015 06:02 AM
Hmcyl
Feb 1, 2015 04:18 PM
Dadslb7
Dec 9, 2014 11:05 PM
