what kinda oil does everyone use
Old Jan 20, 2015 | 05:07 PM
f250white's Avatar
Default what kinda oil does everyone use
I have a 6.0 i was wondering what kinda engine oil does everyone use in there truck i use Rotella now wanted to see who uses what and if they get better fuel milage with different oil thanks
Old Jan 20, 2015 | 05:28 PM
HeavyAssault's Avatar
I ran synthetics in my 2006. Never had any real issues to talk about for the 280k. Use what you can afford with OEM oil filters.
Old Jan 21, 2015 | 11:53 AM
bustedknuckles's Avatar
I bought my '06 new; I used Valvoline Blue Extreme 5W40 from 500 miles to 60,000 miles. It worked fine for me until about 45,000 miles, when I started getting fuel injector stiction. For the next 25,000 miles I tried a lot of things; here's what I concluded:
- Most importantly, changing your oil every 7500 miles is not good; I changed my oil every 7500 miles from 500 to 60,000. I believe this is the main reason I began getting stiction at 45,000 miles. You must stick to a change interval of 5,000 miles.
- Using a good oil additive helps; I started using Archoil 9100 friction modifier at 60,000 miles and still use it every oil change.
- Using a fuel additive that increases lubricity and also increases cetane is a must on the 6.0 diesel.
- Using a fuel additive that prevents gelling is absolutely necessary below 20 F. And if you wait til the temps get down to 20 F, it's too late. You need to add the anti-gel when the temps are above 30 F. Pay attention to the Weather reports, because once it gels, adding anti-gel doesn't help; at that point you need to add something like Diesel Service 911; the one in the red bottle.
I now have 120,000 miles and after a lot of playing around with a few different oil additives I settled on Archoil 9100. Oh, and by the way, I don't have fuel injector stiction any more, and I haven't changed my injectors. They are original and I believe I can run them to 200,000 miles or beyond.
I also realized that using 5W40 is not mandatory for keeping the engine clean. Don't get me wrong, I think, it's the best oil to use, however, the single most important thing is to change your oil at 5,000 miles and use a good oil additive.
To save a little money, I use 15W40 in the summer and 5W40 in the winter.
When the temps get down below 20 F, my truck is harder to start ( it cranks over slower with 15W40). When the temps get down below zero, my truck has a very hard time starting with 15W40. I can start it at -10 F when I use 5W40. Rotating between the 2 oils (5W40 in the winter and 15W40 in the summer) and using Archoil 9100 additive seems to work well for me. This combination addresses hard starts in the winter as well as keeping my injectors clean.
Old Jan 21, 2015 | 04:19 PM
f250white's Avatar
Thanks for the post reckon since i just changed the oil I'll wait to put anything else in it rite now is been in the 30's in the morning and it's kinda hard to start and i was having trouble with the injectors sticking i put in some hot shot about a week ago noticed a change but my fuel milage still is bad from what it used to be
Old Jan 21, 2015 | 04:25 PM
Adrenaline junkie's Avatar
I usually run 5-40 synthetic Rotella. Went extended change intervals (10,000 mi.) only to get stiction issues at about 80,000 miles. I used HotShot Secret to relieve stiction issues and return to good! Since then I've used the Rotella 5-40 with rev x and no issues at 7,500 mile changes. Recently I changed hpop (215,000 miles) due to just wearing out. I hear 03 pumps normally fail at 100,000 so I got a lot of life from it. My injectors are original, but I'm sure tired. I used 15-40 after pump, it was free and I wanted to do 2500 mile oil change in case I got anything inside when I did pump. Got cold here and of course hard starting and rough cold starts. ( I usually cannot plug in and I run plow truck so I have to start in any weather). So I changed back to 5-40 but I'm using Delo as recommended by dieselsite and am happier. I wanted to try 58v bulletproof ficm and after one day , WOW! Runs like its warm within one minute @ freezing temps! Would recommend 5-40 and additive for oil and anti gel for fuel. Definitely recommend dieselsite pump and bulletproof ficm too!
Old Jan 22, 2015 | 08:13 AM
I ran oil change intervals between 7500-10k using various synthetics on OEM oil fitlers and later a oil bypass filter system. I never used oil additives or other snake oil. Never had stiction issues.
BTW if you are using an oil additive at every oil change you still have stiction issues.
Old Jan 24, 2015 | 09:58 PM
Ozz's Avatar
Ozz
I got my 6.0 liter with 112K miles on her. I used Rotella T5 and it seemed to work ok, till winter. I noticed when it was really cold out here in the Seattle area, say 20 deg F, I would have stiction issues when it was really cold. But it would go away for the most part. I changed my oil to Synthetic T6, the entire problem went away. I change my oil every 5000-7500 miles.
Old Jan 25, 2015 | 12:19 AM
Ozz's Avatar
Ozz
I forgot to tell you, when I switched from T5 oil to Synthetic T6, my fuel mpg went up. just my typical driving to and from work i noticed my fuel mileage went from 16 to 18.5 on the freeway.
Old Feb 17, 2015 | 10:33 AM
ChrisGuerrero's Avatar
Hi f250white,
The Shell Rotella T Triple Protection 15W-40 (CJ-4) and 10W-30 (CJ-4) oils are both approved for your Ford 6.0 Diesel engine, as they both meet the Ford Spec WSS-M2C171-E. The Shell Rotella T Triple Protection products are formulated with improved soot control and an exclusive detergent system to deliver outstanding piston and engine cleanliness. Additionally, the exclusive low-ash formulation helps protect the exhaust catalysts and particulate traps found on the latest low emission vehicles, and is recommended by a wide range of OEMS, suitable for both the low-emissions and older model equipment.
-The Shell Rotella Team
Old Feb 24, 2015 | 10:08 PM
relic530's Avatar
I use shell rotella t6 in everything that has a motor, no problems ever
