Missing bad at 2700 & above
Old Jan 20, 2015 | 02:51 PM
dawnrogerl's Avatar
Default Missing bad on speeeding up
My 1999 dodge 5.9 is missing bad. It has a Mad Dog 100 lift pump. I don't have a pressure gage. It acts like it is starving for fuel. Money is tight right now so don't want to replace something that is not the problem. I am questioning the lift pump. Is there any way of checking it without a pressure gage? I unpluged the pump and it acted the same way with it pluged in or unpluged. Any help you all can give me will be appreciated. Thanks
Old Jan 20, 2015 | 11:00 PM
Baradium's Avatar
Wait, are you saying you unplugged the lift pump and ran the truck without a lift pump at all?
If you weren't running low fuel pressure before, you sure did then...
Old Jan 21, 2015 | 05:27 AM
gh0stman's Avatar
Yeah if you unplugged your pump you are damaging the VP. The only way to properly check the lift pump on the truck is to have a pressure gauge. The more you run it with out the lift pump the faster you will end up replacing a $1000 VP.
Old Jan 21, 2015 | 09:10 AM
dawnrogerl's Avatar
Default Pump bad?
Thanks. I am going to get a pressure gage today. Last night I got under thr truck and had my wife turn the key on. Then I had her turn it off and back on bumping the starter. I could not hear anything or feel anything from the pump.
|WYG|SS
Jul 4, 2015 08:31 AM
Feb 5, 2015 12:10 AM
jrsavoie
Shade Tree , Pro-Mechanics & Fabrication
Nov 25, 2014 09:48 AM
12vbomber
Nov 11, 2014 10:58 AM
Stick_Welder
9
Oct 24, 2014 04:10 AM
