hot rod vp44
Old Jan 19, 2015 | 08:54 PM
24vRelentless3's Avatar
Default hot rod vp44
I have a quadzilla adrenaline and have it all hooked up except the part for tapping into my vp. my question is wht wire do I have to tap into on the pump? all help and as detailed would be greatly appreciated! Thanks its on a 2001 24 valve.
Old Jan 20, 2015 | 04:38 AM
gh0stman's Avatar
https://www.dieselbombers.com/5-9l-2...e-tapping.html
Old Jan 20, 2015 | 05:14 AM
Is the wire I need to tap into the wire closest to the engine bay that goes into the pump? amd I was told that the wire to tap into was different than the stock vp because this is a hot rod, or doesn't that make any difference? what wire do I tap into?
Old Jan 20, 2015 | 05:36 AM
gh0stman's Avatar
I don't know if the hot roded version is wired differently. But I believe I tapped the one closest to the engine, cant remember been a while since install.
Old Jan 21, 2015 | 11:52 PM
Baradium's Avatar
There are two wire bundles IIRC. You might only see the top bundle. Take the insulator off of it and it's the wire in that bundle that is closest to the engine. That is on a STOCK pump. I don't know if they wire high output pumps differently (I'm not sure why they would though)
justinsbeck
Jan 18, 2016 12:15 AM
Jul 28, 2015 03:50 AM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
somarillw
Dec 15, 2014 12:00 AM
woodsman27
Dec 9, 2014 09:55 AM
