HELP!! Edge Comp Install!!!!
Old Jan 19, 2015 | 01:26 PM
FF131's Avatar
Default HELP!! Edge Comp Install!!!!
While installing a comp box on my 2000 Dodge Cummins, I discovered my data link connector has been cut off. I don't know why but there's three wires: black/yellow stripe, yellow/green stripe and a yellow/blue stripe. Can I somehow splice the two wires from the edge comp box harness onto the data link connector wires or not? Help!
Old Jan 19, 2015 | 06:22 PM
ramrunner01's Avatar
Might be the only option you have you could try a junk yard and see if you can get a used dlc connector and splice it in most junk yards around here tho recycle all wiring and don't keep any wiring. I ran into this problem on a car at work where someone had cut the connector off and the only way to get the connector was with an entire harness that was a chevy tho may be different at dodge
Old Jan 20, 2015 | 04:45 AM
gh0stman's Avatar
^^^That's what I would do. Try to find a new connector and solder it in. That way if you need to remove in the future it will be a simple disconnect and not damage the comp box.
Old Jan 21, 2015 | 11:37 AM
FF131's Avatar
Thanks guys. Im going to try to find a wiring harness from a 2000-2002 and maybe if I'm lucky I'll be able to simply cut the dlc right off!
RexShoppe
Price Quote - Request A Price
Nov 23, 2015 02:38 PM
Rusted Dragon
Feb 27, 2015 09:46 PM
scottxmorris
Feb 6, 2015 05:33 AM
scottxmorris
Dec 31, 2014 03:20 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
