5x.18 injectors what size turbo.
Old Jan 15, 2015 | 11:55 AM
Whitereaper12v's Avatar
Default 5x.18 injectors what size turbo.
I just found out my injectors are 5x.18 what single turbo should I run on this truck to lower my egts and my smoke?
Old Jan 15, 2015 | 07:54 PM
wpg6.5's Avatar
If you wanna run those injectors full out you'd need a s400 chassis single basically or twins. You could get a 63/68 and have lots left over and spool fast, a 64/71, same thing. A 66/71 or 73 and would still have fuel left over. 66's apparently aren't very fast spooling. Then you could go s464-s471 maybe as a single but be pretty slow to spool aswell unless you had like a spool valve. 5x18s are like twin injectors
Old Jan 15, 2015 | 07:58 PM
Yeah well they are already in my truck. It's what I got it with them already I can go WOT for like 5 seconds before it jumps past 1200.
Im a marine and I don't really have to money for twins I'm actually think I may just save up for a spool valve.
Old Jan 16, 2015 | 10:11 AM
wpg6.5's Avatar
Fair enough man. I'm in the same situation, don't want twins but want biggish usable power. Going s467.7 and a spool valve and 5x16 sac's. I'll report how it does. And hopefully it can help your decision if you haven't bought your set up yet
Old Jan 16, 2015 | 05:40 PM
I did find a used BW s472 96mm turbine 1.32 A/R housing for $400 does anyone know how this would do?
Old Jan 16, 2015 | 06:29 PM
wpg6.5's Avatar
Fairly slow, you def will want a spool valve. Hopefully you have a cam or something and probably high timing. For street use it would be kinda hard to drive smokeless, especially with an auto. You may want a smaller ar housing. If you do go with it. Gonna be tons of air though. And should fly up top
Old Jan 17, 2015 | 09:37 AM
Well if I get this turbo I can get a spool valve for the cost I can justify it. Drive smokeless? I can't do that now. I have black out a interstate before merging. What size housing should I hunt for?
Old Jan 17, 2015 | 10:01 AM
wpg6.5's Avatar
Something closer to a 1.0 would help spool. Not sure what's avalible for 72's
Old Jan 18, 2015 | 10:22 AM
Would this work?
Custom T4 .90-1.25a/r S480 96mm Turbine Housing - Danville Performance
Old Jan 18, 2015 | 07:07 PM
wpg6.5's Avatar
Ya if you went .90 with no valve or like 1.0 with a spool. The 1.0 is probably the better choice with a spool valve.
