Want to make more hp
Old Jan 13, 2015 | 07:17 PM
cumminsbred01's Avatar
Default Want to make more hp
I want to make 500hp-600hp. I'm about to buy a goerend triple disk for the 47re. What more do I have to do to reach this hp. I'm Also adding a draw straw and .093 feed tubes. I would also like to know what precautions I need to take from blowing up my motor and transmission
Old Jan 14, 2015 | 04:41 AM
gh0stman's Avatar
Are you still running stock turbo? That would be a easy way to get there with you current mod setup.
Old Jan 14, 2015 | 05:34 AM
Yes I'm still running the stock turbo. I was thinking about doing a twin setup but using my stock turbo.
Old Jan 14, 2015 | 05:36 AM
gh0stman's Avatar
That should help you out a good bit. More air more fuel more power.
Old Jan 14, 2015 | 05:42 AM
Okay so what turbo would be best and do I need to worry about the transmission after I get the triple disk on there? And do I need to get head studs or anything else for the motor? Also I forgot to mention I don't really tow anything besides my quad and a couple loads of wood each year.
Old Jan 14, 2015 | 05:55 AM
gh0stman's Avatar
You will need a billet input shaft with the triple disk. head studs shouldn't be an issue till you are around 50 lbs of boost.
Old Jan 14, 2015 | 06:14 AM
Okay. With just the mods I have now with the triple disk should the original input shaft hold up until I get a new one
Old Jan 14, 2015 | 06:15 AM
gh0stman's Avatar
yes
Old Jan 14, 2015 | 06:43 AM
Now as far as turbos what a good one that's somewhat cheaper
Old Jan 14, 2015 | 06:45 AM
gh0stman's Avatar
I hear a lot of good things about the super b. But you can bank on atleast 1200 for any new turbo. Maybe you will find one on sale.
