Another OPS question
Old Jan 10, 2015 | 11:44 AM
TurboBoy6.5's Avatar
Default Another OPS question
Decided to check my OPS switch (Opening the T valve) and the truck ran for a second then spit and sputtered and died. Nothing came out of the hose and I'd been driving the truck all morning so it was good and warm. I just replaced it about 3 months ago but I used a Napa brand. Should I replace it again or put a new lift pump on? Or replace both? Also what's a good brand OPS switch to get and where to get it? Thanks.
Old Jan 10, 2015 | 01:29 PM
detroitdiesel idi's Avatar
Ac delco only for ops and lift pump
Old Jan 10, 2015 | 02:03 PM
Mayhem's Avatar
Napa as far as parts house brands go are good mine went out on a Saturday and could not get a AC/Delco so OPS in my truck is from Napa and has been for 2 years Have you run 12 volts to G terminal with the T valve open if fuel comes out LP is working you might want to do the OPS mod save yourself headaches in the long run.
Old Jan 11, 2015 | 08:21 AM
racer55's Avatar
Use AC Delco OPS and google OPS relay mod and install for long term reliability.
Old Jan 11, 2015 | 01:55 PM
HeavyChevy95's Avatar
See Lift Pump Replacement, The Right Way
Joracing3
Sep 10, 2016 05:28 PM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
Dieselhead6.5
May 11, 2015 12:13 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
