Air dog lift pump failure ?
Old Jan 8, 2015 | 10:59 AM
Anh Chà n's Avatar
Default Air dog lift pump failure ?
This morning was 3F here and I got my block heater plugged in so I started the truck easy ... I left it run and when back inside to get ready to work .. but then I came back out it stop running . Then I try to start and it runs again then the engine I stall again . After a few more attempt it still won't run .. I checked all fuels everything is normal. Then I check the lift pump I still hear it running then I try to remove the fuel feeder line at the injection pump then start the truck but there is just some drip of fuel come out from the line .. any ideas guys ? I'm really stuck now
Old Jan 9, 2015 | 04:47 AM
gh0stman's Avatar
What was your fuel pressure right before it happened?
Old Jan 9, 2015 | 08:17 AM
MONSTER EXHAUST's Avatar
FormerVendor
Default airdog Pump
Hi,
It would be best for you to contact AirDog.
Your pump should be covered, as long as you did all the correct paper work.
Here is a contact link Contact AirDog®
and the phone number is 877-421-3187
Old Jan 9, 2015 | 12:45 PM
Anh Chà n's Avatar
Pressure was 17psi at idle and 13psi while driving
landon025
Sep 8, 2015 09:21 PM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
dawnrogerl
Price Quote - Request A Price
Jan 29, 2015 01:03 AM
veggyoilkid
Nov 10, 2014 12:39 PM
