First start in 2 years.
Old Dec 30, 2014 | 03:56 AM
POWERSTROKEMANIAC's Avatar
Default First start in 2 years.
So I'm putting the valve train back together on a 98.5 that has been sitting for 2 years. 2 concerns 1 the oil pan has been off the same amount of time What should I look for?. 2 what is the best way to go about the first start up. Truck did run when parked.
Old Dec 30, 2014 | 11:30 AM
RAW's Avatar
RAW
Rust is a killer. Wouldn't hurt to pop a main cap or two off, maybe a connecting rod cap or two as well. Surface rust inside the block is one thing, but on the rotating assembly is another.
Whenever I start an engine that has sat a while, or has been worked on internally, I disable the fuel system and crank the engine over until there is good oil pressure on the gauge, and sometimes until I see it on the top end.
Old Dec 30, 2014 | 04:48 PM
I really hope there isnt rust set up in there I really dont want to pull that thing haha. Thanks for the help
Old Jan 15, 2015 | 06:39 PM
justinsbeck's Avatar
what we do at my work on a motor that hasn't run in awhile is pretty much what RAW said with the exception that we pop the valve covers and manually oil everything we can possible get oil onto and turn by hand with a big *** bar before disabling fuel and cranking for a bit. one thing to watch for though especially with the VP44 is cranking to much with no fuel lubing that pump...its not a fan of that......
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
Cougdiesel
Oct 19, 2014 10:09 PM
