Raptor pump going down to 6psi at wot
Old Dec 21, 2014 | 09:02 AM
amztroyer's Avatar
Default Raptor pump going down to 6psi at wot
New injector pump so I thought I would get a good lift pump, The truck is completely stock and the raptor can not keep up, I just installed gauges in the truck and I'm not happy because I put on about 3k miles like this, I tow about 20k every day
Old Dec 21, 2014 | 10:08 AM
yjay's Avatar
There's a pressure adjustment screw on the pump. Have you turned it up?
What pressures are you seeing?
Old Dec 21, 2014 | 10:23 AM
amztroyer's Avatar
I'm going to try messing with that today, I'm seeing 15 psi with the key on 13 at idle 10 going down the road empty and 6-8 towing
Old Dec 21, 2014 | 10:38 AM
yjay's Avatar
Mine idles at 18/19. I'd start there.
Old Dec 21, 2014 | 10:39 AM
amztroyer's Avatar
I was so upset because I thought I could just put that pump on and not have to worry about the vp44 starving,
And I did just change the filter so I know there's no restrictions there
Old Dec 21, 2014 | 10:49 AM
yjay's Avatar
Mine was set correctly from the factory, but they do strongly suggest a fuel pressure gauge to verify the setting.
You're probably fine. My injector pump lived for over 200k miles with the stock lift pump towing a gooseneck and you know the pressure was way below 10 psi many, many times. The only reason it finally gave up was the fact that it was run out of fuel, killed the lift pump, and subsequently the IP. I wouldn't sweat it at all.
Old Dec 21, 2014 | 12:19 PM
amztroyer's Avatar
That makes me feel better, I'm going to try bump up the pressure today, I'm going to put about 500 miles tomorrow
Old Dec 21, 2014 | 01:24 PM
amztroyer's Avatar
Update, I adjusted the regulator on the pump, now I am 21psi with the key on, 17psi at idle and 14 at wot.
The truck runs a lot better now, the injector rattle seems a lot more even at higher rpm's
jrock0805
Jul 28, 2015 02:03 PM
jrsavoie
Oct 8, 2014 06:58 AM
